    Dismiss Notice
Overflow water tank leaking
Discussion in 'Plumbing and Central Heating' started by gaz1234, 6 Jun 2021.
  1. gaz1234
    gaz1234
    3 Aug 2009
    93
    Thanks Received:
    Somerset
    Country:
    I’m not sure. I think hot
  2. Sponsored Links
  3. gaz1234
    gaz1234
    3 Aug 2009
    93
    Thanks Received:
    Somerset
    Country:
    I’ve two tanks. Replaced the unit in the larger one
  4. dilalio
    dilalio
    20 Mar 2009
    7,937
    Thanks Received:
    1,293
    Potters Bar
    Country:
    Just get a plumber in mate.
  5. gaz1234
    gaz1234
    3 Aug 2009
    93
    Thanks Received:
    Somerset
    Country:
  6. JohnD
    JohnD
    15 Nov 2005
    74,264
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
  7. Sponsored Links
  8. CBW
    CBW
    26 Sep 2019
    9,074
    Thanks Received:
    2,426
    North
    Country:
  9. fixitflav
    fixitflav
    20 Mar 2018
    1,234
    Thanks Received:
    139
    Stoke-on-Trent
    Country:
    The only way to adjust that type is to bend the rod. I would dismantle the valve, make sure all the parts are clean and the diaphragm is not split. If that doesn't cure it buy a new valve.
  10. gaz1234
    gaz1234
    3 Aug 2009
    93
    Thanks Received:
    Somerset
    Country:
    Fixed it by replacing the standard screws ones with a tool station high pressure one..
    Even the plumbers didn’t have an idea or want to know tbh
  11. fixitflav
    fixitflav
    20 Mar 2018
    1,234
    Thanks Received:
    139
    Stoke-on-Trent
    Country:
    Well done!
Loading...
Share This Page
