I'm new to this forum and would be very grateful for any help with the following matter....
I have a Britony Combi SE boiler and started to experience problems about a month ago. Occasionally when running a bath or shower the hot water would suddenly go and the only way to get it back again would be to reset the 'two position selector switch'. I called our local heating engineers who said that it was a common fault with this model and they replaced a main circuit board (Circuit Imprime FF 61308723). From memory I believe the 70 and 80 lights were flashing. (For the record when we successfully run hot water from the tap all the green led's now flash and we have been advised that this is normal.)
A few days later the same thing happened however this time only the 70 light was flashing. The heating engineers were called again and the 'Over heat security' sensor was replaced.
The problem happened again and 'sediment' was removed from our boiler however we are still experiencing problems.
The engineers seem as puzzled as me... has anyone any ideas?
