overheat
24 Nov 2004
Merseyside
just had a call from a gent . he has an ultimate 120 on a three port unvented system with 19 rads.overheat stat trips every couple of hours.what do you chaps reckon.thinking possible fauly overheat or thermostat or dont know if he has pump overrun.house is about 5 to 10yr old.
I think these control the pump from the pcb. Check out pump over run is working and also any by-pass valve fitted is working correctly as a first port of call.
