Padstone for Concrete lintel
  • Thread starter Thread starter marsaday
  • Start date Start date
M
marsaday
I am putting a concrete lintel into place for my new wall alterations. The span is 1.45m and the new lintel will sit on a new block wall and then into the party wall.
So it is going to go into the party wall my about 110mm and i need to chop out this area. Do i need to create a padstone with slate, or metal or just use compo ?
If it's only a 1.45m span, and the lintel is going in 110mm, and is 100 wide, you won't need a padstone - just some stiff mortar
use a pad stone on the party wall mate its safer that way the job is done right
Dont take long to chop out for a pad
If it is going into the wall by 110mm, and is 100 wide, it doesn't need a padstone as the bearing stress will be quite low. It just needs some stiff mortar or dry pack underneath.
Tell us more about this extra "safety", and also tell us why it is "right" to have a padstone on a 1.4 m concrete lintel
Ok, thanks for info. The span is 1.45, but the lintel size is 1.8m
At 1.4m clear span with a conc. lintel you don't need a padstone - end of story.
