Paint cracking on a plasterboard joint.
25 Aug 2008
Carmarthenshire
I have a problem. before painting a bedroom wall there was a small thin crack in the plaster - which i am positive is where 2 plaster boards are joined. I rubbed down the edges then applied mist coats etc. Now the wall is finished but to my annoyance the crack has reappeared. It is a very thin crack but i can see it :eek::mad:. I have read that there is some sort of jointing tape i can buy - could some one tell me which tape and how to do it and also would i be able to put it on newly painted walls?? :confused::unsure:. Thanks
Jointing tape is applied prior to any plastering and this helps to stop and movement and cracking of the joint. It may not have any in if its still cracking. Best thing is to make the crack bigger, almost like a "V" shape and re fill it with filler and sand it back after.
Thanks for your reply Robbie. Can i just use pollyfilla to fill the crack then or does it have to be a special filler?
It'll still crack I'm afraid. It's a weak joint, and it will move again at some point. There are heavy grade lining papers that might hide the crack, and there are very durable papers specifically designed to handle movement joints. You might get away with opening the crack up, and filling with a 2 part filler to provide strength and rigidity, but I suspect the only asnwer will be to replaster with jointing tape.
Thanks again Robbie. Oh dear Doggit i was hoping to avoid that - i will try the filler first and fingers crossed it works. Thanks for your reply though.
