Is it bare wood? If so treat knots, use solvent primer to cover the knotting,then two coats of solvent based satinwood/eggshell. I wouldnt use emulsion or water based paint on a barf panel. ok on walls etc.
If it's laquer/ or melamine, rub down a little to key, use dulux supergrip or zinnsser bin primer, then two coats of satinwood/eggshell.
