Painting a wooden bath panel white.
9 Apr 2006
Middlesex
Hi.We have a new pine bath panel we wish to paint white,We don't want to paint it in gloss.What options do we have? What would be a good choice?
Thank you.
a matt paint like brilliant white matt emulsion would be fine although its not quite brilliant!!!
also a white water based undercoat would work well
Thank you.
Is it bare wood? If so treat knots, use solvent primer to cover the knotting,then two coats of solvent based satinwood/eggshell. I wouldnt use emulsion or water based paint on a barf panel. ok on walls etc.
If it's laquer/ or melamine, rub down a little to key, use dulux supergrip or zinnsser bin primer, then two coats of satinwood/eggshell.
good luck..
As above, quite like satin wood, Looks the buisness and will last as its near water etc. Dont use emulsion, wont last 5 minutes.
