    Dismiss Notice
Painting Architrave
Discussion in 'Decorating and Painting' started by keenbutconfused, 16 Aug 2006.
  1. keenbutconfused
    keenbutconfused
    19 Jun 2005
    84
    Thanks Received:
    London
    Country:
    I am painting some architrave that has some quite fine detailing on it. I am finding that some of that detail gets lost as I paint it. Is there a trick to doing this or is it just a matter of thinning the paint a bit.
  2. Sponsored Links
  3. paulpolly
    paulpolly
    15 Aug 2006
    12
    Thanks Received:
    Anglesey
    Country:
    i've been trying to get to the office all weekend- and week to finish some design work, but guess what, my beatiful wife decides she wants to re-decorate the bedroom? hit the same problem as you. What i found was that if i removed the existing layers of paint buit up over the years with a good quality paint ramover so that i was back down to the natural wood finish, i could then prime the architrave with a good (thin) primer coat. To retain the detail. i then used a good quality high gloss paint. dont go for the one coat porridge like substance she buy's cos , apparently, its easier. Select a good quality high gloss paint and apply with a good soft & fine 1" (25mm) or smaller paint brush. the key was to take my time.
    I did think of removing the architraves and painting them, then fixing them back with no nails or something, but think she would have killed me? :LOL:
  4. Zampa
    Zampa
    14 Mar 2005
    5,778
    Thanks Received:
    30
    Country:
    You dont need to thin the paint...it could make your problem worse.
    Use a stipplning action when your painting the mouldings instead of an up an down brushing action..which tends to scrape the paint from the brush and causes it to run.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
