Painting garage walls with emulsion and spray gun?
11 Nov 2008
Northamptonshire
I'm going to paint the inside of my garage soon. It is 45sqm, so you can imagine that there is alot of walls to paint.
The walls are unpainted 5 year old concrete blocks.
In the past I have found that painting with a roller is a nightmare. So seeing as I have spray gear for painting cars, why can't I spray the walls. Obviously I will spend alot of time masking, but it will be worth it as spraying will get in all the holes in the blocks.
Has anyone done this before? I assume I need to water down the emulsion? With water?
Any ideas or advice would be great. Thanks
I have spray kit for cars too...but I am pretty sure it wouldn`t work for emulsion. :cry: My M8 -a pro decorator- Has Airless kit specially for emulsion, It might be worth seeing if you can hire this type :idea: Or invest in a 12 inch roller with frame , pole and bucket.
I did the interior of mine about 10 years ago. Mine is a brick interior and I was fed up with everything getting covered in brick/mortar dust. I first painted it with a stabilising solution because the mortar was a bit sandy and then a coat of good quality exterior emulsion paint. I used one of those brushes for fence painting (130 x 40 mm) and it easily got into all the nooks and crannies. It also made the whole garage a lot brighter.
It still looks freshly painted, apart from the cobwebs!
