Painting old wall that is gloss and plaster
Min
27 Oct 2003
Help, what do I do?
I've stripped off the old wall paper in the loo and have bare plaster with patches of gloss paint. I want a painted finish.
I'll rub down the gloss paint to create a key.
What's a good primer? Some of the posts here recommend Dulux Super Grip Primer.
Would you use that? Or something else?
Mary
I'd use one of the Zinsser primers - have a look at their website
  • Thanks
Reactions: Min
Unless you have removed all the wall paper paste carefully, use Zinsser Gardz. You may have to do quite a bit of sanding and filling to get an even level surface between bare plaster and old paint.
  • Thanks
Reactions: Min
Thanks Nige F - Bulls Eye 123 looks good. Can't see I need the Plus.
Thanks OchAye. I have washed the wall four times to get all the paste off. Yes, the sanding and filling it a worry. Thought I'd sand to create key, paint a first coat then sand again.
One of the posts mentioned using steam to get gloss off woodwork. Any idea if that's worth trying on plaster - or would it just degrade the plaster?
Gardz looks like the alkali-resistant paint I've used previously in other rooms - underneath the wall paper was 1950s distemper
Sand to create a key. Sand the edges of the paint a bit more to make them thinner. If you decide to use filler, get a wide knife (taping knife, small plasterer's trowel whatever you like) and fill from over the paint onto the plaster as wide as you can go. Sand again .. the idea is to create a smooth ramp(???) between paint and plaster.
If you have an electric sander it might just get rid of the paint; sorry I am not into steamers but if you overdo the steaming you might damage the plaster (I would rather use warm water and get the patch soaking wet for a few minutes and try again). Also check this site https://www.ecosolutions.co.uk/products/ but I have never used any of their stuff.
  • Thanks
Reactions: Min
Wowsers - water-based, non-toxic, non-caustic, no fumes . . . "Trade Strip" removes all sorts, including oil-based and lead-based from any substrate inc plaster. Game on!
Apart from hating the dust of sanding, I was concerned that it would be lead-based oil paint, so this looks like a viable alternative. And no endless filling trying to get a decent 'ramp'.
Thank you so much! I'll report back when I've tried it.
