Painting over varnish
6 Sep 2012
Flintshire
Hi - I have a varnished back door that I want to paint. Stripping off the varnish seems too much like hard work. Does anyone know of a suitable primer/undercoat that can be laid down on top of the varnished surface please? Thanks.
Give it a good sand down remove dust then give a coat of zinsser bin or gardz (have a look at there products online) then oil based undercoat to go with your top coat.
I dunno about using gardz, it wont be able to penetrate a coat of varnish, personally i'd use bullseye 123
slightly off subject but do you still sand the surface before using these products even though they state no sanding required?
Yep, its always good to de-nib and despite what it says on the tin you're always going to get a far better bond between paint and substrate if its well keyed.
thought I would ask, have recently started using there products after seeing a lot of good things said about them on here, have been sanding as its just the natural thing to do really, but was wondering if I was wasting my time or not.
