Hello!
I have just bought a new house and am in the process of getting it renovated etc. I have decided to start painting the kitchen (just around the units area where extractor etc is going as it'll be easier than painting it afterwards) and I think I've made a bit of a mistake! I bought some Dulux Brilliant White Matt paint and painted one coat on the ceiling (new plasterboard with skimming of plaster). I used a ratio of 50% water/ 50% paint (my first mistake I think!). I have also painted a wall with the same ratio. Basically what I want to know is - how do I fix this? do I need to paint dulux plaster sealer over this? or paint a ratio of 80% paint/ 20% water over this and then apply a final 100% coat?
Also, as it is the kitchen I believe I should use a semi-gloss on the walls/ceiling so I can clean them - am I ok to paint a semi-gloss coat over my first two watered down matt coats? (aaaaaaaaaaaaaaaaaa!!!)
Lastly, my fiancee decided to paint an arch with the same watered down coat and she left some bumps etc on (unbelievable!). Do I just chisel/sand them off and touch them up with the same watered down coat?
Thanks for your help, to be honest I'll probably get a professional in to do the rest of the painting (ceilings at least) as we were both shattered after the weekend and I think I was a bit out of my diy depth
