I have a couple of radiators that have the usual rust spots on the bottom that have lifted the paint. i have rubbed them down in those areas and removed any loose material and have a fairly smooth sanded surface. In the past I have treated these with red oxide paint and then over painted with a proprietary white radiator paint.
Is this a good method ?
I used to paint rads with gloss white but figured radiator paint is designed for rads and the heat. But I suspect it makes little difference and a good Dulux type white gloss will do just as well.
I would hope that using red oxide would prevent or at least delay any surface rust coming through.....
