    Dismiss Notice
Painting skirting board caulk?
Discussion in 'Decorating and Painting' started by LeadFarmer, 31 Jan 2018.
  1. LeadFarmer
    LeadFarmer
    27 Mar 2009
    381
    Thanks Received:
    19
    Yorkshire
    Country:
    Whats the rule when painting the caulk between skirting boards and the wall?
    Should the caulk be seen as being part of the wall, and painted with the wall colour paint, or should it be seen as part of the skirting and painted with the same paint as the skirting?
    [​IMG]
  2. Sponsored Links
  3. ironsidebod
    ironsidebod
    17 Feb 2009
    439
    Thanks Received:
    49
    Nottingham
    Country:
    It isn't usually up the wall like that so you treat it as part of the skirting. That should have been wiped away before it went off leaving a nice gap filling amount flush with the top of the skirt.
  4. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    And you can't easily sand it, either :-/ If it's not yet gone completely hard I'd hack it off and start again.
  5. LeadFarmer
    LeadFarmer
    27 Mar 2009
    381
    Thanks Received:
    19
    Yorkshire
    Country:
    Point taken, that’s that’s just a small area, most of the remainder is fine.
    So would any caulk behind the skirting normally be painted the same colour as the skirting?
  6. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    Yes, I'd have thought so.
    • Thanks Thanks x 1
  7. Gerrydelasel
    Gerrydelasel
    5 Jan 2016
    2,220
    Thanks Received:
    186
    Lancashire
    Country:
    Ideally you wouldn't use caulk at all except maybe for very thin gaps. It's not suitable for anything over about 2mm, as you have discovered. White filler should have been used instead, smoothed and lightly sanded off to look like a solid part of the skirting. What you have looks more like bathroom sealant! :rolleyes:
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
