    Dismiss Notice
Painting stainless steel cooker hood
Discussion in 'Decorating and Painting' started by creative101, 19 Jul 2020.
  1. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    I’m looking to paint a stainless steel cooker extractor hood black. I’m unsure which primer and paint to use given this will be exposed to heat.
    ideally looking for a smooth finish but don’t mind the textured finish either.
    Any recommendations?
  2. Burnerman
    Burnerman
    7 Feb 2008
    22,739
    Thanks Received:
    4,438
    Northumberland
    Country:
    Its fairly unorthodox to paint stainless steel, but you must use a special primer.....Rustoleum do an aerosol called Combiprimer which does the job. The same firm also does top coat finishes.
    The hood must be completely grease free and lightly rubbed with fine grade wet and dry paper. I’d guess you aren’t going to do this with the hood in place!
    John :)
    • Thanks Thanks x 1
  3. Sponsored Links
  4. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    I’ll be removing the top part which easily screws away. Not sure how easily I can remove the actual hood.
    Most paints I’ve seen are Matt black rather than gloss. Just not sure how the matt finish will look.
  5. Burnerman
    Burnerman
    7 Feb 2008
    22,739
    Thanks Received:
    4,438
    Northumberland
    Country:
    Hmmm me neither!
    Personally I’d go for gloss I think.....probably easier to clean.
    John :)
  6. Sponsored Links
  7. Nige F
    Nige F
    28 Jun 2005
    21,123
    Thanks Received:
    1,724
    Country:
    You'll not see a painted De Lorean.
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
