Painting wood that's had OB gloss then WB gloss
9 Nov 2009
Renfrewshire
I will be starting to paint my living room wood work soon and I've stumbled on a problem...
The rest of the house had been painted with OB gloss so it was just a case of roughing the paint with 130 grit and undercoat / coat with WB.
However when I tried to sand the living room paint the top layer scraped off in patches leaving what looks like gloss underneath, it was a test area on the side of a door so not to worry just yet!
I found an old tin of Crown quick drying gloss in the garage so I assume whoever painted it just put a coat over the gloss to hide the yellowing.
How do I move forward with this, if I sand it the finish is going to look terrible.
Best bet in my opinion is to keep over-coating it - it gets tougher as it gets thicker.
No, just a couple of quick coats slightly thinned, good synthetic brush.
What grade and type of abrasive paper are you using?
Silicon carbide or the wet n dry stuff is a lot less forgiving than aluminium oxide
I will be using Dulux Quick Drying as the tin is already open, it appears that it's already thinned as it needed 3 to 4 coats in the other room!
