painting wood
13 Sep 2004
I stripped all the paint off the balustrade of my staircase and plan install some spindles to replace some wooden panels
After this I will have:
- red pine newel post (stripped and sanded)
- Oak handrail (stripped and sanded)
- Oak spindles (newly installed).
My hope is that oak and pine will blend well together. I looked around for paint and got confused. There are several different products in the market to varnish interior wood (all sorts of oil, solvent varnishes, water/acrylic varnishes; liming; eggshell pain, diamond hardwearing paints......).
I cannot obviously try them all. What would be your recommnedation?
Acchillo
what you use depends on what you want it to look like when its finished.
do you still want to see the natural wood?
do you want it a different colour, but still want to see the wood?
do you want it to be a totally different colour and not see the grain of the wood?
is it going to take a bashing from children etc?
answer some of those questions and we can get a bit further with the question
Thermo
Absolutely right! thanks Thermo
We would like to keep the wood effect and grain, so no dye/colour that is not a wood varnish.
The oak (old and new) should be varnished, I am not sure about the newel post as it is a different wood. We wil ltry to varnish and if we will not like the effect we will paint it white.
I suspect a staircase will receive some sort of bashing, so it should be a resistent paint.
