Parallel vs tapered couplers
I
IainWatson
HI all,
Have a supplied piece of brasswear which has a male 1/2" BSP tapered end.
Do I have to use a tapered female iron end coupling or will parallel suffice (connecting a Geberit cistern to 15 mm Mains cold supply)
Thanks,
Iain
I mean first of all take off the brass connector, then screw the pushfit to the cistern, then push in the copper pipe:cool:
is that what they teach now pushfit ?
Tap or tank connector ?
and do I have this right, screwing the brass nut of the connector to the cistern's 1/2" male end (tapered) with plenty of PTFE will do the job, allowing supply tube to be pushed in t'other end as per normal?
Iain
They do indeed
Iain
Tank connector, a John Guest one or something, completely remove the brass fitting from the cistern, then screw in the plastic tank connector, here I've tried to draw something up, the red fitting is the tank connector
Hope it helps :)
hold on someones confused here.
john what is this tank connector and copper pipe for ?
tank connectors are used for overflows.
You can't use for mains feed?
Pardon me if I seem to lack knowledge, I'm just still an apprentice :cry:
how do u plan on shutting off the water when the cistern is full?
:LOL: :LOL: :LOL:
No need to arsey now, looks like someone has their work cut out!
oh thought the float valve could screw on to the tank connector, but it has its own connection to the tank
sorry
im getting worried now on what they have been teaching you.
now the valves sorted, what did you mean can't use mains ?
I meant can't you have
mains [connects to]-> tank connector [connects to]-> float valve
