Parkside cordless charger
17 Apr 2007
Its for a 20v drill.
Seems not be charging the batteries.
There's three terminals on the charger. Multimeter readings are
2.73v between + and -
5.01v between ID and -
Since these voltages are lower than 20v, presumably a faulty charger.
One battery's led says its fully charge yet sitting on the charger, the charge light is still flashing after 30 mins.
you are trying to charge with compatible battery and charger i assume as not all batteries or chargers even from same manufacturers are compatable
and as john d say try other batteries if you have them and even other chargers and tools and the faulty or non compatable one is the one that always crops up as the problem
If you still have your reciept they should have a 3 year warranty. Contact them here even if you haven't got the reciept but registered the product
You might have a credit card statement showing the purchase?
On the Lidl club card it keeps a record of your receipts. I don't know how long for.
I am lucky, we also have a Parkside where I volunteer, so can just try charging a battery on their charger, but I will go down to my charger with volt meter, and see what it shows.
3 volts, 5 volts, and 1.3 volts on the three termials with no battery connected, so it seems likely your charger is OK, and it is the battery at fault.
Mine in the two battery type, and it is working fine.
Thanks for that!
If you have 3 volts, 5 volts, and 1.3 volts on the three terminals, I'm curious how its charging 20v batteries.
One of my batteries is fully charged according to its led yet even in the charge for 30 mins, not showing fully charged.
Thanks for that!
I reckon the charger and/or battery are intelligent so once the battery is attached to the charger, it starts to supply the volts the battery needs and measuring terminals at rest is meaningless?
Never really looked at it, as it works, I have 5 batteries 4 x 2 Ah and one 4 Ah the latter is smart, and I have just plugged them in when discharged and unplugged when charged, never considered how it works. Was unaware of open circuit voltage until today.
The 12 volt battery charger for the car is the same, until connected to a battery it has no output.
I've contacted Lidl so perhaps their tech team will suggests tests to do.
As I said above if a fully charged battery is not recognized as charged by the charger, it suggests a faulty charger.
Will post again when resolved.
