parquet floor
15 Jan 2007
Hi, just about to lay a parquet floor but dont want to use beading around the edges,i would like to cut into the bottom of the skirting instead and slide the blocks under.Could you please recommend a tool to do this,thanks
Hi. I ve just finished laying a parquet floor. To cut under door frames etc I used a Bosch PMF 180 E-its a cheaper version of a Fein Multimaster.
Sounds an awkward job doing all the skirting this method particularly if your blocks are t & g, would nt it be possible to remove them then replace after the job ?
