Parquet Laying
Parquet flooring as in wood blocks in a pattern like herringbone?
NO.
Not before you first install plywood (12 - 14mm thick) for stability and levelling any cupped or uneven floorboard.
You can use 4-6mm exterior grade plywood if the floorboards are very flat. I sand mine flat first. Saves on hight in door ways. But as woody said you need thicker if you have any cupping/crowning of boards. Guess you will have.
