T
thisidentifiesme
Hi there
I currently have a Keston Celsius 25 system boiler installed in a 4th floor flat. The problem is it is installed in the centre of the flat and has a vertical flue that is only suited to Keston boilers.
We are looking at a Worcester Bosch 25SI combi to replace it.
It would need about 6m of extension flue and would need to be 80/125mm due to the distance as 100mm would only allow an extension of about 4.6m (from my understanding)
The boiler would fit in the existing cupboard and the flue would go through the ceiling and then left across 6m of living room ceiling and out the wall.
I am looking to get all the parts required for the job myself then arrange for a gas safe person to do the installation as we are pretty tight on funds and this appears to be the cheapest solution.
I would really appreciate if someone could help me understand exactly what parts we would need.
As far as my understand so far goes
6m 80/125MM flue extension with brackets
Inspection hatches (would this just be three?)
What I am confused about is the flue itself, and what elbow I would need to join the flue from the boiler to the extension. Would the 80/125mm fit the boiler going into the ceiling? Or is it a different size and requires something else to convert?
What flue do I need, can a horizontal flue fit an extension without issue or is a special type?
Would be ever so grateful for any advice or anything I may have missed.
Welcome the knowledge and apologies if its a bit confusing
