Hi all!
My house was built circa 1935 and has foundations as thick as sheet of card
All of the interior walls have vertical cracks developing in the corners where the inside walls meet the outside structural walls, and I've discovered recently that it's because the inside walls are built from wooden frame and brick.
I'm currently refurbing the kitchen where one of these cracks has been present in the corner for years. I've removed the loose plaster which has exposed the wooden batten where it meets the cavity wall.
What would be the best way to proceed with patching over the wood? Would any kind of flexible filler be best or is there something I can apply to the wood before filling?
The size of the wooden exposed 'batten' is about 3" after the loose plaster has been removed.
Thanks for any advice!
