Patio Joins
20 Nov 2026
Hi, we have a paving slab type patio outside our front door which has looked like this all year, weeds, dead leaves etc,
Weve started weeding but most of the mortar? we assume was between them has now completely eroded, theres nothing under them, maybe some aggregate was put down however it is now mostly mud, weve been offered setting sand to fix this, but based on my research setting sand won’t last in cracks this wide and shallow. If anyone has any product recommendations, advice or ideas, i’d really appreciate it.
Thank you so much, i’ve attached further photos if theyre useful.
Rip it up and do it properly. If you can't do research and find out how it should be done then get a professional in.
That’s a really disappointing response, thank you for taking the time, I’m in the process of doing my own research, and thought that posting on a forum where people who might be able to offer insight was a worthwhile endeavour. I see now, that was a mistake and I should’ve expected this response. Is the whole point of this website not to ask?
A lot of the information I’m able to find online is able to provide information on what I should do if i’m starting from scratch, I’m not sure how to fix this patio, and i’d like to do it without ripping the whole thing out which is the only instructions i’m able to find. If there is a way to do it, I hope the lovely folks here might be able to help.
You asked for advice and that is what I gave you. Trying to save that crazy paving would be a waste of time and money. It's reached the end of it's life.
Why is it a mistake? You've been given sound advice you just don't happen to like it
you're spot on about setting sand mate, if the slabs are rocking or sat on bare dirt/mud the brush-in compound will just crack and wash out within a few months. brush-in stuff like joint-it or easyjoint only works if the slabs have a solid sub-base and minimum 25mm joint depth. if they're loose you're better off lifting the wobbly ones, bedding them properly on a semi-dry sand and cement mix, then pointing them up with a traditional 3:1 mortar mix using a pointing iron.
I agree about taking it up as I think you would be wasting money and time trying to fix things that won't last. You would then end up having to fix it again.
Have a look at replacing it. Take some measurements, see what you like and go from there.
Don't waste money or time if they are rocking and muddy underneath etc.
Hope you don't mind me suggesting that.
quicker to rip it up and start again than trying to repair it - it doesn't look like a particularly good job in the first place, i would lift it, make sure it has a good base and start again
