Hi, I was wondering if anybody can help?
Ford Focus 2.0l Ghia
Diesel
52 Reg
My car started to have trouble starting (intermittently), then shortly after I found the battery had died.
I changed the battery this morning and now the car will not start at all. the PATS light flashes intensively and I have found it will eventually give me an error code. the error code is 1:5 (1 flash - pause - 5 flashes)
I have researched this code and it tells me the PATS system does not recognise the key. My push button fob key
I tried a different key, the normal key (it has a blue square in the corner) I assume this is a master key?
This gives me exactly the same fault.
Is there any way of resetting this? could it be a different fault and the code is mis-leading?
I have found plenty of help in programming a new key but it says to use the master keys mentioned above to do it. I also find it hard to believe that 2 keys could go faulty at the same time
I'm stuck, any help is greatly appreciated
Regards
Gary
Diesel
52 Reg
Regards
Gary
