    Dismiss Notice
Paving mortar dilemma
Discussion in 'Building' started by _Tiny_, 16 Sep 2020 at 1:15 PM.
  1. _Tiny_
    _Tiny_
    7 May 2019
    17
    Thanks Received:
    Country:
    I need to lay some white mint indian sandstone. They are really light in colour, almost white, and I am concerned that over time the yellow from the sand will leach through and stain the slabs. I intend to prime the back with a slurry of snowcrete and SBR, which should help I guess. I have a choice for bedding mortar: yellow sharp sand or nearly white building sand. I'll probably use snowcrete again, since its a small area. I'd prefer to use sharp for strength,but white building sand for colour. Its getting laid on a thick bed of whacked type 1, about 200mm since it was low to start with.
    Interested to know what others would / do do.
  2. Sponsored Links
  3. 23vc
    23vc
    17 Apr 2015
    2,093
    Thanks Received:
    301
    Warwickshire
    Country:
    I’d use the sharp sand
    You could joint up using something else like Geofix or a custom coloured building sand mix , so the colour of the bedding layer doesn’t matter
  4. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,574
    Thanks Received:
    257
    Country:
    custom coloured? dye? :eek:
  5. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,574
    Thanks Received:
    257
    Country:
    as above , the mortar shouldnt matter so much . most important thing with natural stone is a full bed .
  6. 23vc
    23vc
    17 Apr 2015
    2,093
    Thanks Received:
    301
    Warwickshire
    Country:
    Whatever floats your boat
  7. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,574
    Thanks Received:
    257
    Country:
    doesn’t float my boat. you suggested it.
  8. Sponsored Links
  9. 23vc
    23vc
    17 Apr 2015
    2,093
    Thanks Received:
    301
    Warwickshire
    Country:
    Might float the OPs boat
  10. _Tiny_
    _Tiny_
    7 May 2019
    17
    Thanks Received:
    Country:
  11. _Tiny_
    _Tiny_
    7 May 2019
    17
    Thanks Received:
    Country:
    Not really fussed about pointing. Probably a bog standard grey mortar to contrast the slabs. Just dont want my white slabs to develop a yellow tinge
  12. 23vc
    23vc
    17 Apr 2015
    2,093
    Thanks Received:
    301
    Warwickshire
    Country:
    Your slurry coat on the back of the slabs should stop anything showing through (y)
  13. _Tiny_
    _Tiny_
    7 May 2019
    17
    Thanks Received:
    Country:
    OK sharp it is.
    Thanks all for the input
Loading...
Share This Page
