Through servo warm because nobody else is dealing with them. But the board is purely a pump over run.. So your previous post regards problem is not caused by this.
Problems with pcb not supplying enough power to pump - 160v instead of 240v - have wired pump direct to mains (running constantly) - when timer kicks boiler on, fires up okay but relay on board "chatters" constantly.
Looking for replacement or alternative or if board can be repaired (cant be more that 15 components on it and board discoloured around large blue capacitor).
Have tried servowarm and greeted with no longer supply parts for that boiler - better buy a new one!!
