Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Unfortunately the manufacturer's fault finding information seldom includes anything about testing individual items to determine which item is at fault.
How come a boiler had three replacement PCBs in less than 24 months. The fault that was damaging the PCB was shorted turns in the gas valve solenoid. The minimalistic fault finding chart for the boiler only gave a DC resistance for the solenoid, the DC measured resistance of the solenoid was correct. Hence the gas valve was not faulty.
AC impedance measurements ( never mentioned in the fault finding chart ) confirmed there was a fault in the coil. ( suspected as such since the PCB's all had the same damage to the driver for the gas valve. ).
Yes he used his multi-metre and said the resistance on the fan was reading 9 and didn't know if that was good and would check with WB. When he came back the next time he told me 9 meant it was bad and should be closer to 300 as told to him by WB
Benny , you say that you are a man that doesnt want for means, why do you not start up a company and go and do all these repairs or upgrades that you presume that you are an expert in ??? I know because you havent a feckin clue
