penetrating damp bay window
31 Aug 2009
Hertfordshire
There is damp coming through the bay window wall at the top, below the window at the two corners only when it rains. Outside the windowsill - which is made of mortar - is cracked at the corners also and has not been painted for some time. The brickwork outside has been rendered but looks pretty sound.
I think that the windowsill could be the problem. Without having to re-render the whole window sill, is there a product I could use to patch up the cracks and is there something I can use to make the windowsill waterproof?
its all dry at the moment because its not rained for some time.
Patching any external weather bearing surfaces will only be a temporary solution.
Sooner or later the cracks will reappear unless you do something more permanent/robust.
I'm finding it difficult to imagine a sill made from mortar?
