Hi all,
I have a victorian house with a ground floor lower than the external street level. I have a damp wall which I believe is due to this. On digging out a concrete section level to the damp on the outside, I found it to be very damp, (there was plastic sheeting below the concrete where water had pooled). I want to remove the plastic sheeting and concrete and replace with something that will fix the internal problem.
Will digging down deeper, (below the internal floor level), filling the hole with some sort of drainage ballast and re-concreting over the top solve the problem or can anyone help with another solution? The damp is about half way down the side of the house which is an external wall directly on to a downward sloping street/pavement.
