Permitted development of agricultural buildings.
Discussion in 'Building Regulations and Planning Permission' started by Rob broom, 8 Sep 2021.
  1. Rob broom
    Rob broom
    17 Nov 2020
    45
    Thanks Received:
    Country:
    Hi there.
    I have some questions about permitted development and Class Q development.
    If a plot of land has an agricultural building on it that has been used as a barn (hay and feed store) until recently, what is the likely hood of planning being permitted to turn it to a house?
    I understand that the building has to retain the shape of the original barn, but can it be demolished and replaced?
    The barn we are looking to convert has been in place and recognised by the council as an agricultural building since the 1970s. It is built from timber and galvanised sheets, rather than a stone building or modern steel frame construction. It would need to be demolished and replaced if we got the permission.
    Any thoughts in my questions would be gratefully received.
    Many thanks
  2. Sponsored Links
  3. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    19,961
    Thanks Received:
    2,223
    Devon
    Country:
    In planning, once something is demolished, it no longer exists so anything built in its place needs to meet planning regulations as if there was nothing there to start with.
  4. Rob broom
    Rob broom
    17 Nov 2020
    45
    Thanks Received:
    Country:
    Thanks for the reply.
    What about if the sides were removed and the roof was “suspended” while block walls were built? Then simply work through replacing the old roof with a new one?
    that way the building doesn’t actually get “demolished”, but the whole construction is replaced bit by bit?
    any thoughts?
    thanks
  5. Rob broom
    Rob broom
    17 Nov 2020
    45
    Thanks Received:
    Country:
    Or can you build scaffolding all the way around the barn and cover it the scaffold with sheeting?
    Then carry out the work under the cover of the scaffold?
    just floating ideas!?
  6. lostinthelight
    lostinthelight
    11 Feb 2016
    3,248
    Thanks Received:
    629
    monmouthshire
    Country:
    Someone did that sort of thing by building hidden by straw bales
    https://www.bbc.co.uk/news/uk-england-surrey-35928269
  7. ^woody^
    ^woody^
    3 Sep 2006
    34,738
    Thanks Received:
    4,705
    West Mids
    Country:
    No you can't replace bit by bit in parts and end up with a completely new building, or everyone would be doing it. :rolleyes:
  8. Sponsored Links
Loading...
Share This Page
