Neighbour's boiler had cut out due to low water pressure.
I have re-pressured the system, but presumably I need to reset the boiler itself.
Big black box on the boiler has the thermostat knob for water temperature and there is also a chrome nut and shaft mounted on the box with a metal pin in the hollow shaft which looks like it could have had a button over it.
Is this the reset for the water pressure ? , and is reset procedure to hold it in till the boiler fires (with appropriate triggers set) , or just to press it once ?
Can't find a manual anywhere...
thanks
thanks
