- Joined
- 3 Nov 2024
- Messages
- 34
- Reaction score
- 0
- Country
I have a detached double garage with a block and beam floor and intend on installing an RSJ to act as a mid span for new joists I’m going to fit alongside the existing trusses to create a storage floor
I am about to instruct a structural engineer to spec everything up but before doing so (and forking out for it) I wanted to get a sense of what the likely options will be to support the 6m long steel, given the walls are single skin and from what I read, you can’t build brick piers directly on top of b&b floors.
If the S/e is likely to come up with some elaborate and hideously expensive suggestion given these limitations then I’d rather not bother, and just leave it here.
Any ideas? Thanks
Any ideas? Thanks
