I want to run a telelphone cable upstairs vias the inside wall which I'll be dot'n'dabbing in the near future thus hiding the telephone cable (as well as other stuff too).
Firstly I need to move the Telewest socket over to the other side of the window. Can I simply remove the wires, move the box and re-install as necessary? Do I need to make sure the exposed telephone cables don't touch eachother whilst I have them removed from the box?
Secondly, when I reconnect the original telewest lines, I want to add a second line on the same connections at the back rather than having to use an extension plug in the front of the socket. I will then run this up the wall into the first floor to its own socket. Can I then piggy back this extension socket in the same way and route to another box in another room?
