Pilot holes for large drill bits
20 May 2015
Birmingham
I used a 20mm forstner bit to give me a well 10mm deep. I need to drill a 10mm wide hole through the timber (45mm thick).
I used a 3mm wood bit so it would centre perfectly. On a test piece, using the 6mm wood bit next meant the hole was off centre. So on the main work, I used a 6mm hss bit which worked. But when I used 8mm and then 10mm, the edge of the hole became splintered.
How do I avoid this?
What was the correct technique for what I wanted to achieve?
Should i have drilled the hole first and used a forstner bit second?
The edge of which hole? The small hole inside the well? Or where it comes out?
If out, then add a piece of wood under the main timber, preventing break through damage
I should have taken a pic.
The forstner “hole” is a recess for the collar of a masonry bolt to rest on. That bit is fine.
The main hole for the shaft of the bolt is chipped on the forstner side. I used a scrap bit of wood for the opposite side and there’s no breakou.
