hope this helps, this was an earlier post from a few months ago on a conversation about measuring gas leaks, i work in a training centre and sometimes we can play
right the first version of tests is as follows:
created 4mb gas leak over 2 mins on a compression fitting, took a very accurate reading of the meter, went back 2hrs later and calculated gas lost, i appreciate it isnt very scientific as i was taking manual readings but i purged the gas before i started to get it bang on a reading, and again after only 2hrs isnt exact science but good enough till you guys come up with a better test criteria
so result is gas lost over 2hrs x 12 x 365 to give an equivelant for a whole year is 0.876m3 for the year, a quick google check has gas at £0.06 per kw/hr.
so check the calculations/formula here
0.0002m3 in 2hrs x 12 x 365 = 0.876m3
to give costs 0.876 x 39 (cv) /3.6 x £0.06 = £0.56.94
so a 4mb drop over 2 mins on a 22mm copper installation uses £0.57 worth of gas per year.
next i measured the pilot usage on a BAXI 401 BBU, again over 2hrs and found:
0.0426m3 so again
0.0426 x 12 x 365 = 186.59m3 x 39 / 3.6 x £0.06= £121
so a pilot on a BBu uses about £121 per year, thats one for the energy efficiency bods amongst us, again not perfect science but close enough,
Read more:
http://www.diynot.com/forums/viewtopic.php?t=275462&start=45#ixzz1Y9i88kW1
