Pipe bung 8mm
bsr
5 Aug 2008
Gloucestershire
Does anyone know of a internal pipe bung or similar suitable for 8mm copper? I need to solder a fitting onto the end of a piece that won't drain down properly.
It doesn't need to hold pressure. I need to get it far enough along the pipe that I can solder the end. I've seen a little rubber thing on a stick you can use for 15mm.
How will you retrieve the bung if there's a fitting on the end of the pipe?
Cut it further back where it may be out of sight then use a compression fitting to remake once soldered.
  • Thanks
Reactions: bsr
Have you considered lifting the pipe up higher to solder it or is there still too much water?
