Pipe detectors??
12 May 2007
Whats peoples opinion on these pipe detectors, are they any good, whats a good make as looking to get one.
Having bought every type on the market (up to £80) a few years ago I found NONE actually worked well enough to give you any confidence before drilling. Most were very susceptable to the type of brick (ie the iron content) and surface condensation.
I did consider buying a proper wall tie locator. These look like a mini metal detector and would no doubt do the job. Since they are about £400 I gave it a miss.
The cheap ones from B&Q etc are OK for live electric cables but useless for copper pipe.
You have to be about 2-3cm from the pipe in the open air to get the tracer to register. If the pipe is buried under carpet, underlay, floorboard etc, it won't find a thing. It won't even find pipes behind plasterboard walls.
It is very good at finding gripperod :!:
Always found that most people can find them with a simple hammer and nail, no need for expensive bits of kit :lol:
My drill bit found a 1.5mm T&E at 09.00 am putting up a curtain rail and then my bolster found a 2.5mm T&E at 17.00 removing the excess plaster around a doorway. :roll:
Both cables were outside the prescribed zones with no protection. It was also the first day of the job. :(
Nothing's as good at finding gripperod as my finger tips. :evil:
