Pipe Lagging
15 May 2009
West Midlands
I have a run of pipe work that runs over the ceiling of a single story kitchen. The pipes keep freezing as the temperatures are getting really low. I want to insulate the pipe work to protect it from freezing. Can you guys recommend which is the best type of lagging available?
Is Hair felt lagging any good? The foam stuff might be too thick for where I need to fit the lagging.
Any recommendations will be appreciated.
If it's running over a ceiling and freezing ina kitchen, then, that must be cold, leave your heating on slightly.
Best suggestion in your case would be to get as much rockwool up and over the pipes as possible.... remove any insulation from under the pipes so that the heat from the room leeches through the ceiling and is trapped by the rockwool, keeping your pipes frost free.... When you think that you have enough insulation up in the loft, then add some more.....
I leave the heating on, but there is no radiator in the kitchen and No one is living there, so the kitchen is not being used for cooking. Otherwise it would heat up. I'll try rock wool.
