check that you have a neutral at the pump
Hi yeah there’s positive neutral and earth wired to pumpcheck that you have a neutral at the pump
No I meant test it with a multi meter and ensure you have a live and neutral supplyHi yeah there’s positive neutral and earth wired to pump
What’s best way to do thisNo I meant test it with a multi meter and ensure you have a live and neutral supply
set your multimeter to the correct setting and place one probe on L on the pump and the other on NWhat’s best way to do this
The brown being the switch live or the black that’s connected to mains in the controller?The stat is wired wrong.
The middle terminal is 1 which the brown wire should be connected to.
Then the black wire should be connected to 2 (left) if you want the pump to stop at the temperature the stat is set at.
Or 3 (right) if you want the pump to start.
Hi this is the readingset your multimeter to the correct setting and place one probe on L on the pump and the other on N![]()
hat will be the thingumyjig thenHi this is the reading
45v?Hi this is the reading
