pipe work layout
9 Oct 2007
Can anyone tell me if there is a correct way to return water to the boiler? i.e. does the domestic hot water return go into the central heating return or the other way round?
The reason i ask is my house has the central heating completely on 15mm and the domestic hotwater on 22mm.
Would there be a right or wrong way?
It's a tee - make your choice :roll:
Have you got 15mm all the way from/to the boiler?
Which "goes into" which? Neither goes into either. The two pipes join into one pipe, which is the combined return pipe. It should be large enough to take the flows from both pipes, so normally 22mm.
I'd be worried about your CH circuit being no bigger than 15mm. How many rads do you have on it?
Okay
thanks for the replies, i'll try to be clearer (that'll be a first), 22 from the boiler to the pump 22 to the mid way valve 22 to 1st downstairs rad then 15 all way round up to upstairs then back round to the boiler, this then joins the 22 return from the tank.
7 rads in total.
So should the heating have priority into the boiler with the hotwater entering from the side.
Or hotwater into the boiler with heating entering from the side. :?
Priority is decided by the operation of the motorised valve. It doesn't make any difference which pipe connects to the side branch of the tee.
