pipework for 3 bar pump?
10 Dec 2008
Cheshire
I am fitting a 3 bar pump for a new shower. I plan to run the new pipework up to loft and across to an Aqualisa digital shower unit.
My questions are;-
1) Will compression fittings be ok for 3 bar pressure?
2) Should I run all new pipework in 22mm? I will have to reduce to 15mm at shower unit as this has 15mm connections.
The aqualisa is available with or without pump. I have the unit without a pump so am fitting a seperate one. I have checked with their technical dept and they say this is fine.
yes as you say it is ok.
compression fittings will be ok and 15mm pipework is all you need on these showers.
