I am just about to put in all the pipework for my new shower. The shower will be on a gravity fed system. I will be making a connection to the cold water tank in the attic for the cold and I am going to use a surrey flange connection to the hotwater tank for the hot. My instruction manual for the shower says that the pipework should be 22mm outside diameter, to reduce pressure loss, and to insert reducers as close to the shower valve as possible, as it will only accept 15mm pipes.
Does anyone see a problem with me just making the whole pipe run from start to finish for both the hot and cold from 15mm pipework instead of changing diameters in the run????
