PIR defect code opinions please
8 Jun 2007
Newcastle upon Tyne
What is the general consensus on a PIR code for a consumer unit with the
bottom edge of the busbar unshrouded (old MEM).
Thanks in advance
Good one that. Is the cover held on with SCREWS rather than those plastic twist lock things??
If screws then i would have said code 2 otherwise code 1
If it's within the consumer unit no code - it's no worse than the average bus bar chamber.
Don't forget, you're supposed to isolate via the mains switch before removing the cover. :wink:
Hi chaps, I just consider what could feasably happen.
If it is the twist locks a child could feasably get these open and fingers in.
Also you know what DIYers are like alittle knowledge and zap they get a belt.
Now admittedly going into a CU without isolating quite honestly deserves a good whack but the more protection the better.
If the people using the CU were instructed and trained then I would go for 3 but householders aren't so a 2 from me at least.
Sorry am I a little OTT when it comes to this, busbar shroud pence to buy benefit is instant.
This is the problem with codes, very little guidance and open to interpretation.
NICEIC day last wed, pointed out the same problem, thou some bstards really spin it to create works
FROM ESC document best practise guide
Code 2
"This code is to be used to indicate that the observed deficiency requires action to remove potential danger.
The person ordering the report should be advised that, whilst the safety of those using the installation may not be at immediated risk, remedial action should be taken as soon as possible to improve the safety of the installation"
I would say busbar shroud here
A code 3 is "requires further inverstigation" so in this instance you can't use that.
It not a case of being over the top it's just wrong to code it. You're inspecting to BS-7671 2008 so what reg number would you quote?
The codes have worked for years and I don't see a problem. The only problem is when inspectors make up their own regs and try to code them.
So what would you code for an old Wylex rewirable which never had a bus-bar cover in the first place?
Code 4 at a push if it is in an insulated enclosure as it isn't being used in accordance with manufacturers instructions.
It there are exposed live parts with the cover on then it will warrant a code 1.
I don't think this warrants a code on a PIR, but if it were possible to fit one, then I would - if only to protect the sparky working on a live board!
I would not code it.
Agreed although I would document it as an observation as I'm sure you would.
Oharaf, be careful about coding along the lines of the ECS document as a single code 2 could deem an installation as unsatisfactory. That would be ridiculous for a missing busbar inside a consumer unit where a tool is required to remove the cover.
Taken from the ECS PIR document:
"It would not be reasonable to indicate a satisfactory assessment if any observation in the report had been given a Code 1 or Code recommendation."
