Hi all,
Looking for advice, garden room build using 18mm OSB and timber joists for walls, would I be better dropping from 125mm pir between the joists
to 100mm between the joists with 25mm across the front to help with thermal bridging, and changing from
6x2 to 5x2 timber to keep wall thickness the same.
Second silly question, I can buy 2 x 50mm pir cheaper than 100mm, will doubling up the 50's to get to 100 be better, worse or no difference in insulation values.
with thanks.
Rusty
with thanks.
Rusty
