PIR
1 Apr 2004
I have a 500w PIR and was wondering what the correct circuit to put it on.
I have had some people say it can spur from an RCD protected circuit, and others have said it must not.
what is ok please
Darren
ideally it should be rcd protected as its electrical equipment outside but its not that critical.
the problem with putting it on a rcd that serves other stuff too comes if it starts to leak. If you do put it on a rcd protected cuircuit then at least make sure you have some form of double pole isolation in place in case it starts to cause problems.
