Pitch of stairs
27 May 2010
Lancashire
Hi, i am in the process of fitting new spindles and i thought the pitch of the stair case was 45 degrees but i have just found that the pitch is 50 degrees. Is this normal-the house was built in the 30's?
43 is usually the maximum unless its an alternative tread space saver
Thanks for reply big-all. No the stair case is not a space saver. i have checked the angle again in several places and it still comes out at 50 but i guess i will have to work with what ive got.
Are you looking at the correct side of the protractor or whatever you are using as it could well be 40degrees from horizontal which would be 50degrees from vertical.
Jason
Jason
my thought exactly hence my last statement :D :D ;)
