'Pitting/Mottling' on new gloss paint
30 Jul 2008
Yorkshire
Hi
Can't think of another term for this. Redecorating a bedroom and put on first gloss coat around 10 days ago and all fine. Rubbed down, cleaned throughly and started to apply second coat. Doing fine with door frame and skirting but when I applied to a flat window cill, half way around the room, it started to form a pitted/mottled pattern within seconds - not smooth at all.
Left it and re-commenced the next part of the skirting after the cill and, although not as bad, looks to be 'pitting' too.
Can't be the paint as it's new and both the first full coat and the areas painted with a second coat prior to the cill are all fine.
I did seal around the window with PVC 'cladding' and then used a frame sealant to fill in the gaps. I noticed that the sealant, although applied over a week ago, still isn't fully set (and therefore will it ever be???).
Is the paint reacting with something in this un-set sealant? If so, can I seal it somehow? Most importantly, is there a way of sorting the cill without having to rub right back top bare wood?
Any help appreciated.
At some point someone has used silicone based polish on the cills.
Too late to save the one you are doing but a cream cleanser before you paint will get it off.
Simon.
What you describe is called crazing, this will often occur when the newly applied paint is unhappy with what is beneath it. This could be some form of contamination or the application of a liquid gloss onto an already cured gloss system.
Crazing can often resemble small cracks in your newly applied paint system or a more globular pock marked affect can also occur, tell me please what paint system you are trying to apply eg, oil or waterbased and also any prep that you have done.
Help me and I will help you.
Dec.
