Hi all,
Am just about to redo my kitchen having successfully rewired my lighting circuits last year and have pretty much worked out all my electrics, just have a couple of questions, all related to my pretty diagram:
Firstly, the cooker circuit currently goes to a connection unit (A) from which the cord runs to the cooker, however this is going to be directly above the hob (not good). The current supply is shown in green. The question is, can I just bury a cable on the blue path (in conduit) to move the switch out of the way (in which case I'd either tile over the junction or leave a blanking plate there), or should I dig the cable out of the wall and either place a junction box under the kitchen surface, or should pull the cable all the way down to the floorboards and then reroute up the brown path?
Secondly, I have had comments from friends about the placement of switches near hobs and there are notes in various places suggesting not having a DP switch with built in socket because the socket placement might mean the cord being burnt on the hob (in addition to the extra load on the cooker circuit). This suits me fine, however, what are the minimum distances for the DP switch and sockets to be from the hob, and what is the recommended distances (B + C). I realise the maximum distance from the DP to the oven is 2m.
Other than that does my plan look OK?
Simon
Simon
