I'm just trying to learn a little about woodworking but I'm having problems with my plane. I only own a single plane (it's an Axminister No. 7). My problem is that when I try to use it, the blade is pushed back in relation to the breaker so that the breaker ends up in front of the blade. I think this might be happening because I put camellia oil on the blade after sharpening it and now that's preventing the friction between the blade and the breaker from keeping the two in place. If I remove the oil using ethanol, will this make it liable to rust?
